8 years agoError (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
Info: Command: quartus_cdb -t import_compile.tcl Info: Using INI file /home/temp/Desktop/workspace/wisconsin5/wisconsin5/bin/conv/quartus.ini Info (125061): Changed top-level design entity name ...
8 years agoI checked, the top fitter has not completed. But according to my optimization report, the 2 attributes of my utilization are around 70% and the other two are 40% and 50%. If I over used the board, can actual resource utilization differ this much with estimation? And I only have the base.flow.rpt (base fitting was finished, but not top fitting).
