8 years agoError (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
Info: Command: quartus_cdb -t import_compile.tcl Info: Using INI file /home/temp/Desktop/workspace/wisconsin5/wisconsin5/bin/conv/quartus.ini Info (125061): Changed top-level design entity name ...
8 years agoBased on the quartus_sh_compile log, fitting has actually finished successfully. Sort the files in the compilation folder by date and check the last files and see what logs where written to at the end, before the compilation crashed.
