Error (215039): Power Analyzer (quartus_pow) cannot be run. When will be fixed ?
I have checked with Quartus 17.0 STD and 18.1 STD run power Analyzer during compilation option is NOT Grayed Out.
Can you delete db and incremental_db folder and add set_global_assignment -name FLOW_ENABLE_POWER_ANALYZER OFF line in your .qsf file and try.
Try by creating new project.
If possible can you share your design let me try from my side.
Anand
Hi Anand,
Thanks for the inputs.
I tried after deleting db and incremental db, I see it still grayed and giving the same error after compilation.
Would it be an issue with My licence ?
As I'm trying to compile it with 30day free licence available in the tool.
Please find the attached design archive.
Thanks & Regards,
Nanjunda
- AnandRaj_S_Intel7 years ago
Hi Najunda,
No.
By checking i found that
- In MAX 10 SA/SC family device the run power Analyzer during compilation option is Grayed Out (meaning always enabled).
- And also i can compile the project successfully using Quartus STD 17.0,17.1 &18.1.
Anand
