Error (213009): File name "output_files/afu_fit.green_region.pmsf" does not exist or can't be read
As of 01/01/2020 the following have become Unlicensed with the Acceleration Stack Version 1.2.
; Assembler Encrypted IP Cores Summary ;
; Vendor ; IP Core Name ; License Type ;
; Altera ; PCIe SRIOV with 4-PFs and 2K-VFs (6AF7 00FB) ; Unlicensed ;
; Altera ; Low Latency 10Gbps Ethernet MAC (6AF7 0119) ; Unlicensed ;
; Altera ; Low Latency 40Gbps Ethernet MAC and PHY (6AF7 011B) ; Unlicensed ;
; Altera ; Signal Tap (6AF7 BCE1) ; Licensed ;
; Altera ; Signal Tap (6AF7 BCEC) ; Licensed ;
4315 Info (16677): Loading final database
4316 Warning (292015): License for core 6AF7_0119, version 0000.00 is expired.
4317 Warning (292015): License for core 6AF7_00FB, version 0000.00 is expired.
4318 Warning (292015): License for core 6AF7_011B, version 0000.00 is expired.
According to the documentation "You do not need to purchase the license separately for these IPs."
Please advise ASAP to what is required to get a new license?
