Error (213009): File name "output_files/afu_fit.green_region.pmsf" does not exist or can't be read
where can i get a new "Free" License for Quartus® Prime Pro Edition 17.1.1:
Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Warning (115005): Unlicensed IP: "PCIe SRIOV with 4-PFs and 2K-VFs(6AF7 00FB)"
Warning (115005): Unlicensed IP: "Low Latency 10Gbps Ethernet MAC(6AF7 0119)"
Warning (115005): Unlicensed IP: "Low Latency 40Gbps Ethernet MAC and PHY(6AF7 011B)"
Warning (115004): Unlicensed encrypted design file: "/opt/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/hello_world/bin/hello_world/build/qdb/_compiler/afu_fit/root_partition_2cedade0/17.1.1/final/1/netlist.model"
Warning (115004): Unlicensed encrypted design file: "/opt/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/hello_world/bin/hello_world/build/qdb/_compiler/afu_fit/root_partition_2cedade0/17.1.1/final/1/names.model"
Warning (115004): Unlicensed encrypted design file: "/opt/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/hello_world/bin/hello_world/build/qdb/_compiler/afu_fit/root_partition/17.1.1/final/1/netlist.model"
Warning (115004): Unlicensed encrypted design file: "/opt/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/hello_world/bin/hello_world/build/qdb/_compiler/afu_fit/root_partition/17.1.1/final/1/names.model"
Simon
