Nade786
4 years agoError (209034): Can't find JTAG Server + JTAG server stopped
I am using Win 10, Quartus 18.1 with an arrow-blaster (with latest driver installed).
I am trying to program a .jic file to my Altera Stratix V device.
However, the programming fails w...
YuanLi_S_Intel
4 years agohave you try to program a SOF file? does it work?
Also, can you check if you have the USB Blaster driver setup correctly?
Nade786
4 years agoHi Yuan,
Thank you for the reply.
1) I have tried to program a SOF file but it does give the same error as stated originally :
Error (209053): Unexpected error in JTAG server -- error code 44
Error (209012): Operation failed
2) I am using an Arrow-blaster with the latest version (version 2.5) which can be found here ->
The programmer is capable of locating the hardware under 'hardware setup' - please see attached image.
Thanks for the assistance,
Warm Regards
