Error (209027) Verification failed
thank for your replay. i will try give some more information:
Intel® Processor: IC FPGA 10K LE CYC-3 7GR UBGA; EP3C10U256I7;
it's not PC laptop and it is not use on motherboard.
the processor burn using jam file on one station which have OS win7 and its using some other jtag burn program (not quartus).
the verification checked at other station, was OS winXP and one year ago we upgrade to win10 and then all the problems started. not all devices failed, most are pass successful, but several are failed. some of the failed after trying again pass the verification.
we use quartus 13.0 programmer. i try to use higher quartus version such as 16.0, 17.1, 18.1, 20.1 - all same results.
i am not developer, i am the test engineer of the system.
also, when i try to fully burn the file, at quartus, its successful. only when i try to make verify configure its failed.
