12 years agoError (209015): Can't configure device. Expected JTAG ID code
Hi, I'm getting this error anytime I want to program two of our cards (out of 10): error (209015): can't configure device. expected jtag id code 0x025030dd for device 1, but found jtag id ...
10 years agoI do see this is an old thread, wants to tell what I do see on a BeMicro CV A9 board (Cyclone V A9 FPGA)
Error (209015): Can't configure device. Expected JTAG ID code 0x02B140DD for device 1, but found JTAG ID code 0xFFFFFFFF. It do have a build in USB blaster and does works normal fine with different test I have done. Now I did port a big project from another dev board Cyclone V GT board and it all compile fine When programming the BeMicro board I do get the error at 99% but it still work fine with smaller project. I then had look into the schematic for the PSU and it's clear the there are a much smalle PSU on the beMicroboard only 4 amps for the core where the V GT borad do have like 7Amps. also on the beMicroboard there are an Led10 which will show all PSU are fine...it does turn off shortly on 99% so I'm pretty sure that the big project (all as pipline) just draw to much current and the FPGA / Blaster loose all data just downloaded :-(
