12 years agoError (174068): Output buffer atom "soc_system:soc_inst|soc_system
Hi, I have built up an FPGA system in Qsys starting with the GHRD reference design and adding components. I actually built a simialr system for an Arria V Dev Board and that worked fine. Now wh...
11 years agoI'm seeing this same error. Any suggestions?
jagumiel
5 years agoI came here loooking for a solution, but I founded what I was doing wrong.
After the first compilation, when the fitter fails, you must run the following TCL scripts:
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
