Error (171011): Can't assign node "led" to location PIN_AA24 -- node is type Combinational cell
Thank you for your kindness.
led <= calc_returndata;
and I was able to implement it.
However, the LED did not light up and there was no file output.
If there is any concern, it is related to qsys. I have the following connection, is it correct?
I am presuming that you want returndata in the Platform Designer system to appear on the LED. You need to export the returndata interface (double-click in the Export column and give it a name) and instantiate the system, connecting the exported interface (single signal interface, I presume) to the led output. You can see the instantiation template you'll need in the Generate menu in Platform Designer. You'd need to recompile the design of course.
Again, I don't know how this fits into HLS, but for normal FPGA design, this is what would be required.
