8 years agoError (169281): There are 469 IO input pads in the design
I get the following error message in Quartus when I compile my code: Error (169281): There are 469 IO input pads in the design, but only 293 IO input pad locations available on the device. ...
8 years ago --- Quote Start --- Quartus doesn't know anything about your board. Check the Pin Planner to make sure your I/O location assignments are set correctly, but it clearly seems like there are too many I/O in your design for the device you are targetting. I don't know what VT System FPGA Manager is (is that a synthesis tool?). --- Quote End --- VT System FPGA Manager is a tool from the company Vector that executes Quartus for compilation of the VHDL code, and uses its board as target. When I do it directly on Quartus it doesn't know anything about my board so I should probably stick to the VT System FPGA Manager but the problem is that the compilation takes forever (over 1.5 hours) and I had to cancel because I couldn't wait for it so long. However compiled a similar design before, and it only took 20 minutes, don't know why It takes so much time now. It is almost the same design. Just added some input ports.
