yy1
5 years agoError (15653): The Fitter cannot find a legal configuration for the following atoms
Arria 10
Error (15653): The Fitter cannot find a legal configuration for the following atoms. Update any outdated transceiver PHY IP cores, correct any illegal pin assignments, and then recompile y...
- 4 years ago
From the error log that you shared, I can see below 2 possible issues
- Is your NativePHY IP updated to match with your Quartus version ? If not then pls regenerate your NativePHY IP again
- Your PMA output VOD setting maybe causing some issue ?
- Open your NativePHY IP to cross check again to ensure there is no warning or error message
- Try out different output VOD setting
I can help you to review your design if you can share your design QAR file here.
dlim
Deshi_Intel
4 years agoHi,
dlim
yy1
4 years agoHi,
I find the code bug that the phy output port did not connect to any port.
Thanks for your reply.
Jamie
