Amerakim
3 years agoError (12061): Can't synthesize current design -- Top partition does not contain any logic
Hello, I am fairly new to Verilog HDL and I started with trying to print out a simple "hello world". But when i tried to synthesize my code, the error " Top partition does not contain ant logic" pops...
ak6dn
3 years agoVerilog that you feed into the synthesis tools needs to represent constructs that imply hardware (gates, registers, memory, etc).
You might start by reading this:
https://people.ece.cornell.edu/land/courses/ece5760/DE2/tut_quartus_intro_verilog.pdf
and this:
https://www.jameswhanlon.com/writing-synthesizable-verilog.html
If you had a module like this:
module top; $write("Hello, world!"); endmodule
that is NOT a construct that can be synthesized into logic.
