10 years agoError 12007.
I have been on this error for quite a while now, I have read all the other threads but i haven't seen a way to solve this issue.
The code is attached. ------------------------------------------------------------------------------------------------------------------- Info: ******************************************************************* Info: Running Quartus Prime Analysis & Synthesis Info: Version 15.1.0 Build 185 10/21/2015 SJ Lite Edition Info: Processing started: Fri May 27 14:20:43 2016 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off procpld -c procpldtop Info (20030): Parallel compilation is enabled and will use 2 of the 2 processors detected Error (12007): Top-level design entity "procpldtop" is undefined Error: Quartus Prime Analysis & Synthesis was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 739 megabytes Error: Processing ended: Fri May 27 14:20:57 2016 Error: Elapsed time: 00:00:14 Error: Total CPU time (on all processors): 00:00:23 Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 0 warnings ------------------------------------------------------------------------------------------------------------------- Thanks.1 Reply
The project is looking for procpldtop, but you havent got a module called procpldtop in your project.
