8 years agoerror 12006 help
I am getting the error 12006 when i try to compile this code and cant see whats wrong with it can anyone help please? library ieee; use ieee.std_logic_1164.all; entity mux2_1_struct ...
Ravin
4 years agoHi
I am also getting similar error when i tried to use the UART IP in my project. Kindly suggest some steps to overcome the issue please.
Error as folllows
Error (12006): Node instance "comb_3" instantiates undefined entity "Altera_UART_16550". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
