12 years agoError (10818) What is wrong ??
Hi I'm try write this code. I don't now what is to change:confused:
Quartus log: Error (10818): Can't infer register for "CLK_OUT" at PISO_SPI_LCD.vhd(40) because it does not hold its value outside the clock edge Error (10822): HDL error at PISO_SPI_LCD.vhd(40): couldn't implement registers for assignments on this clock edgelibrary ieee;use ieee.std_logic_1164.all;
--use ieee.std_logic;
--use ieee.std_match;
entity PISO_SPI_LCD is
generic(DATA_IN_LENGTH: integer :=9);
port(
DATA_IN_XBIT : IN bit_vector((DATA_IN_LENGTH-1) downto 0);
CLK_IN : IN bit;
NRESET : IN bit;
DATA_OUT : OUT bit;
CLK_OUT : OUT bit;
READY_OUT: OUT bit); -- 1= ready to send new data 0= is sending
end PISO_SPI_LCD;
architecture first of PISO_SPI_LCD is
signal send_is_running_status : bit :='0'; -- 1= runn 0= idle
signal new_data_to_send_status : bit :='0';
signal DATA_IN_TMP : bit_vector ((DATA_IN_LENGTH-1) downto 0);
signal DATA_IN_TMP2 : bit_vector ((DATA_IN_LENGTH-1) downto 0);
signal CLK_OUT_TMP : bit :='0';
signal COUNTER : integer range 0 to 16 := 0;
begin
init: process (DATA_IN_XBIT) is
begin
if(send_is_running_status = '0')then
DATA_IN_TMP2 <= DATA_IN_XBIT; -- copy data to burref when sennding is disable
send_is_running_status <='1';
end if;
end process init;
set_data: process (NRESET,CLK_IN) is
begin
if(NRESET'event and NRESET = '0') then
DATA_OUT <= '0';
elsif(CLK_IN ='0')then -- if falling clk
if(new_data_to_send_status ='0')then
DATA_IN_TMP <= DATA_IN_TMP2;
new_data_to_send_status <='1'; -- enable start to transfet data
elsif(new_data_to_send_status ='1') then
DATA_OUT <= DATA_IN_TMP(DATA_IN_LENGTH-1); -- get MSB bits and send to output
DATA_IN_TMP <= DATA_IN_TMP(DATA_IN_LENGTH-2 downto 0 ) & '0'; -- shift left data
CLK_OUT <='0';
end if;
40 elsif(CLK_IN ='1') then -- if rising clk -- line 40
if(new_data_to_send_status <='1')then
CLK_OUT <='1';
end if;
end if;
end process set_data;
end architecture first; This is my first post, if something is wrong:oops: please write.. Please help and tips. Thank you.
