8 years agoError (10759) when compile boardtest.cl kernel
when i run to compile boardtest.cl kernel, have the bellow error : error (10759) the verilog hdl error at boardtest_system.v :object kclk_finish declared in a list of port decralation cannot be rede...
8 years ago --- Quote Start --- Info (125068): Revision "top" was previously opened in Quartus II software version 16.0.2. Created Quartus Prime Default Settings File E:/intelFPGA/17.1/hld/board/terasic/de1soc/examples/boardtest/bin/boardtest/top_assignment_defaults.qdf, which contains the default assignment setting information from Quartus II software version 16.0.2. --- Quote End --- It seems the BSP you are using is not compatible with your version of Quartus. Check your board manufacturer's instructions as to which version of Quartus you should be using.
