14 years agoError 10500: VHDL Syntax
I am working on a code for a basic vending machine that will give out a product at 75cents BUt for some reason I dont know how to fix this syntax error
Library ieee;
Use ieee.numeric_std.all;...
14 years agoOk I am struggling to keep up with all th idea everyone is saying. (WHICH IS GOOD it is helping out alot and thank you)
--- Quote Start --- If you don't want latches then either use clock edge so creating registers or keep it as it is but define what should happen if int_count is not max value. And any other areas. The decision to drive the next state is up to the way you want it to be. If you use elsif as you have done then priority is given to first test and if not true then moves to next... --- Quote End --- That worked out well to remove the latches from the first case. And now I have a problem of my vector money -It is tested in two process which I know is bad but I am not sure how to start or add to my code to fix it Once again here is the current code
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
Entity Lab06 is
Port (
Clock :IN std_logic;
Reset_n :IN std_logic;
Quarter_in :IN std_logic;
Dime_in :IN std_logic;
Nickel_in :IN std_logic;
Pennny_in :IN std_logic;
Coin_Return :IN std_logic);
End Lab06;
Architecture Behavior Of Lab06 is
Signal int_counter: std_logic_vector(25 downto 0);
Constant MAXVALUE: std_logic_vector(25 downto 0):= "10111110101111000010000000"; --One Second Count
Type State_type is (wait1, penny, dime, nickel, quarter, enough, excess, vend, change);
Signal current_state,next_state: state_type;
Signal Money: std_logic_vector(6 downto 0);
Signal Red_Bull: std_logic;
Signal Change_Back: std_logic;
Begin
Counter_Clock:Process (clock, reset_n)
Begin
If reset_n = '0' Then
Int_counter <= (Others => '0');
Elsif (rising_edge(clock)) Then
If int_counter = MAXVALUE Then
int_counter <= (Others => '0');
Else
int_counter <= int_counter + '1';
End If;
End If;
End Process;
Sync:Process (clock, reset_n)
Begin
If (reset_n = '0')then
Current_state <= Wait1;--Wait1 is the default state_type
Elsif(rising_edge(clock))Then
If (int_counter = MAXVALUE)Then
Current_state <=next_state;-- Advance the state(Red Bull)machine
End If;
End If;
End Process;
Comb:Process(clock,current_state, Quarter_in, Dime_in, Nickel_in, Pennny_in, money, Coin_Return)
Begin
If (rising_edge(clock)) Then
Case(current_state)is
When wait1=>
If (money = "0000000")Then -- No money in vending machine
next_state <= Wait1;
Elsif (Quarter_in = '1')Then -- Money is inserted
next_state <= Quarter;
Elsif (Dime_in = '1')Then
next_state <= Dime;
Elsif (Nickel_in = '1')Then
next_state <= Nickel;
Elsif (Pennny_in = '1')Then
next_state <= Penny;
Elsif (money >= "1001011")Then
next_state <= Enough;
Elsif(Coin_Return = '1')Then
next_state <= Change;
Else
next_state <=Wait1;
End If;
----------------------------------------------------------------- After Quarter Inserted, next step
When Quarter =>
Next_state <= Wait1;
----------------------------------------------------------------- After Dime Inserted, next step
When Dime =>
----------------------------------------------------------------- After Nickel Inserted, next step
When Nickel =>
----------------------------------------------------------------- After Penny Inserted, next step
When Penny =>
When Enough =>
If (money >= "1001011")Then
Next_state <= Excess;
Else
Next_state <= vend;
End If;
When Excess =>
Next_state <= vend;
When vend =>
When Change =>
When OTHERS =>
End Case;
End If;
End Process;
----------------------------------------------------------------- Money calculation
Money_Calc:Process(Current_state,money)
Begin
Case (current_state) is
When wait1 =>
Money <= Money;
When Quarter =>
Money <= Money + "0011001";
When Dime =>
Money <= Money + "0001010";
When Nickel =>
Money <= Money + "0000101";
When Penny =>
Money <= Money + "0000001";
When Enough =>
Money <= money;
When Excess =>
Money <= Money;
When vend =>
Money <= Money - "1001011";
When change =>
Money <= "0000000";
When OTHERS =>
Money <= Money;
End Case;
End Process;
End Behavior;
And here are my new errors Warning (10492): VHDL Process Statement warning at Lab06.vhd(142): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10492): VHDL Process Statement warning at Lab06.vhd(144): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10492): VHDL Process Statement warning at Lab06.vhd(146): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10492): VHDL Process Statement warning at Lab06.vhd(148): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10492): VHDL Process Statement warning at Lab06.vhd(150): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10492): VHDL Process Statement warning at Lab06.vhd(152): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10492): VHDL Process Statement warning at Lab06.vhd(154): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10492): VHDL Process Statement warning at Lab06.vhd(156): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10492): VHDL Process Statement warning at Lab06.vhd(160): signal "Money" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Warning (10631): VHDL Process Statement warning at Lab06.vhd(138): inferring latch(es) for signal or variable "Money", which holds its previous value in one or more paths through the process Info (10041): Inferred latch for "Money[0]" at Lab06.vhd(138) Info (10041): Inferred latch for "Money[1]" at Lab06.vhd(138) Info (10041): Inferred latch for "Money[2]" at Lab06.vhd(138) Info (10041): Inferred latch for "Money[3]" at Lab06.vhd(138) Info (10041): Inferred latch for "Money[4]" at Lab06.vhd(138) Info (10041): Inferred latch for "Money[5]" at Lab06.vhd(138) Info (10041): Inferred latch for "Money[6]" at Lab06.vhd(138)
