Error (10500): VHDL syntax error at nios2_led.vhd(5) near text "ã"; expecting "end", or "begin", or
I use Quartus Prime Lite Edition.I'm having trouble compiling.
I wrote the following code, but I get an error.I don't think the syntax is a problem, but why? Let me know if you understand.
library ieee;
use ieee.std_logic_1164.all;
entity led_press_button_nios2 is
port (
CLK : in std_logic;
button : in std_logic;
LED : out std_logic
end led_press_button_nios2;
architecture behavioral of led_press_button_nios2 is
component nios2_system is
port(
button_pio : in std_logic;
clk_clk : in std_logic;
led_pio : out std_logic
end component nios2_system;
signal button_wire : std_logic;
signal led_wire : std_logic;
begin
button_wire <= not button;
nios2:nios2_system
port map(
clk_clk => CLK,
button_pio => button_wire,
led_pio => led_wire
LED <= not led_wire;
end behavioral;
Error content
Error (10500): VHDL syntax error at nios2_led.vhd(5) near text "ã"; expecting "end", or "begin", or a declaration statement
Error (10500): VHDL syntax error at nios2_led.vhd(6) near text
Error (10500): VHDL syntax error at nios2_led.vhd(7) near text
Error (10500): VHDL syntax error at nios2_led.vhd(8) near text
Error (10500): VHDL syntax error at nios2_led.vhd(9) near text
Error (10523): Ignored construct Nios2_LED at nios2_led.vhd(4) due to previous errors
Error (10500): VHDL syntax error at nios2_led.vhd(12) near text "ã"; expecting "begin", or a declaration statement
Error (10500): VHDL syntax error at nios2_led.vhd(13) near text "ã"; expecting "end", or "port", or "generic"
Error (10500): VHDL syntax error at nios2_led.vhd(14) near text
Error (10500): VHDL syntax error at nios2_led.vhd(15) near text
Error (10500): VHDL syntax error at nios2_led.vhd(16) near text
Error (10500): VHDL syntax error at nios2_led.vhd(17) near text
Error (10500): VHDL syntax error at nios2_led.vhd(18) near text
Error (10500): VHDL syntax error at nios2_led.vhd(19) near text
Error (10500): VHDL syntax error at nios2_led.vhd(20) near text
Error (10500): VHDL syntax error at nios2_led.vhd(22) near text
- RRomano001
Contributor
Hello, your code as appear here compile hassle free.
inspect or delete and rewrite offending lines one at a time
supposing line 5 is after port declaration a forbidden character seem there.
- EricMunYew_C_Intel
Can you try below.
component xxx
port ();
end component;
