10 years ago
Error (10500) for storing coordinates pixel of a binary image
Hi. I am novice working with FPGAS, I want to add all the coordinates pixels of an image, and each pixel is composed by a coordinate pair (i,j) But I have a mistake when I compile my code.
I previously saved the mif file into ROM. My binary image is 256x256 I really need the help.:cry:
Thanks!
[SUP]library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity covariance is
end entity;
architecture behavioral of covariance is
component ROM1 IS -- Into this memory is the binary image to analyse
PORT
address : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
clock : IN STD_LOGIC := '1';
q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0)
END component;
type Mat1 is array (0 to 1, 0 to 0) of integer range 0 to 256; -- pixel
type Mat2 is array (0 to 1, 0 to 0) of integer range 0 to 65536; -- pixel's accumulator
signal clk, done: std_logic :='0';
signal add_rom : std_logic_vector(15 downto 0):= (others => '0');
signal out_im : std_logic;
signal pixel: Mat1;
signal acum : Mat2;
--pixel<=(0,0);
acum<=(0,0);
BEGIN
process (clk)
begin
if (falling_edge(clk))then -- If there is CLK
if(done='0')then --
for i in 0 to 256 loop
for j in 0 to 256 loop
if out_im = '0' then -- Compare it with zero the first pixel
add_rom <= add_rom + "0000000000000001"; --
pixel <= (i,j);
acum <= acum + pixel;
end if;
end loop;
end loop;
end if;
end if;
end process;
END behavioral;[/SUP]
And the error that appears after compilation is
[SUP]Info: *******************************************************************
Info: Running Quartus II 64-Bit Analysis & Synthesis
Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition
Info: Processing started: Wed Aug 24 00:53:34 2016
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off covariance -c covariance
Info (11104): Parallel Compilation has detected 4 hyper-threaded processors. However, the extra hyper-threaded processors will not be used by default. Parallel Compilation will use 2 of the 2 physical processors detected instead.
Error (10500): VHDL syntax error at covariance.vhd(30) near text "acum"; expecting "begin", or a declaration statement
Info (12021): Found 0 design units, including 0 entities, in source file covariance.vhd
Info (12021): Found 2 design units, including 1 entities, in source file rom1.vhd
Info (12022): Found design unit 1: rom1-SYN
Info (12023): Found entity 1: ROM1
Info (12021): Found 2 design units, including 1 entities, in source file contador.vhd
Info (12022): Found design unit 1: contador-Behavioral
Info (12023): Found entity 1: contador
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 477 megabytes
Error: Processing ended: Wed Aug 24 00:53:35 2016
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01[/SUP]
1 Reply
    You accum assigned before the begin. It must be assigned inside the begin - end pair. before the begin is for declarations only.
    But there are several other issues here:
    Why have you declared the mat1 and mat2 types as 2d array with really only 1 dimension? why not just write:
    type Mat1 is array (0 to 1) of integer range 0 to 256;
    This allows acum to be assigned as you did:
    acum <= (0,0);
    with you current declaration:
    you need to assign acum like this:
    acum <= ( (0), (0) );
    Next - what do you expect the for loops to do in your code? loops are unrolled when the code is compiled. Apart from the fact that out_im is currently unconnected, your signals only get the last value assigned to then, so add_rom will always be +1, pixel will always be (256, 256) and acum cannot assigned because you didnt define a + function for your Mat2 type.
    This looks rather like a software program, not HDL.
