16 years ago
Error 10392
I have the following VHDL configuration file (which I got from someone else).
configuration ssi_rtl_cfg of ssi is
for rtl
for all : tmr_dff
use entity sta101_lib.tmr_dff(rtl);
end for;
for all : ssi_tap_tracker
use entity sta101_lib.ssi_tap_tracker(rtl);
end for;
for all : ssi_ckd
use entity sta101_lib.ssi_ckd(rtl);
end for;
for all : ssi_struct_reg
use entity sta101_lib.ssi_struct_reg(rtl);
end for;
for all : ssi_shift_ctrl
use entity sta101_lib.ssi_shift_ctrl(rtl);
end for;
for all : ssi_shifter
use entity sta101_lib.ssi_shifter(rtl);
end for;
for all : ssi_sb_ctrl
use entity sta101_lib.ssi_sb_ctrl(rtl);
end for;
for all : ssi_ssic
use entity sta101_lib.ssi_ssic(rtl);
for rtl
for all : ssi_ptr_gen
use entity sta101_lib.ssi_ptr_gen(rtl);
end for;
for all : ssi_cnt_gen
use entity sta101_lib.ssi_cnt_gen(rtl);
end for;
end for;
end for;
end for;
end ssi_rtl_cfg;
On the line highlighted in red, I get the following error.
Error (10392): VHDL Block Specification error at ssi_rtl_c.vhd(82): cannot find "rtl"
This looks like valid VHDL, and it works with the Cadence NC-VHDL compiler. It's not the best coding practice, I know, but is there some reason Quartus doesn't like it? The architecture "rtl" is supposed to refer to an architecture of the entity sta101_lib.ssi_ptr_gen. This architecture is called out in another file which is also in my project and which compiled correctly.
Is there some restriction on hierarchical configurations in Quartus?
John Jones
1 Reply
    What I had to do to make this work was create a configuration for the rtl architecture that the compiler could not seem to find. I created it in the same design file and then I had problems with the compiler not being able to see the library. This is a VHDL error and I had to add a library and use directive just before each of the two configuration design elements.
    After all that, it compiled and fitted.
