Error (10327): VHDL error at QA4.vhd(48): can't determine definition of operator "">""
- 5 years ago
I am not a VHDL expert but I believe that the less than ">" operator has been used to compare two type of value: std_logic_vector and integer.
Greater than and less than are relational operators, while using relational operators is that the two numbers being compared must be of the same 'type'. An integer cannot be compared to a std_logic_vector type value.
From what I get from another case:
You can use explicit numeric types SIGNED or UNSIGNED. Alternatively you can use a library that treats all std_logic_vector as SIGNED or UNSIGNED type: IEEE.STD_LOGIC_SIGNED respectively IEEE.STD_LOGIC_UNSIGNED.
I hope it helps.
Richard Tanp/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
I hope it helps.
Richard Tan
I believed that I have answered your question and I yet to receive any response from you to the previous question/reply/answer that I have provided.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
