Error (10232): Verilog HDL error : index 22 cannot fall outside the declared range [21:0] for vector "address"
Coming back to this issue that remains unresolved. I added another MM Slave and got the same problem:
Info (12128): Elaborating entity "stamp3_platform_designer_mm_interconnect_0_router" for hierarchy "stamp3_platform_designer:inst_stamp3_platform_designer|stamp3_platform_designer_mm_interconnect_0:mm_interconnect_0|stamp3_platform_designer_mm_interconnect_0_router:router"
Error (10232): Verilog HDL error at stamp3_platform_designer_mm_interconnect_0_router.sv(195): index 22 cannot fall outside the declared range [21:0] for vector "address"
Error (12152): Can't elaborate user hierarchy "stamp3_platform_designer:inst_stamp3_platform_designer|stamp3_platform_designer_mm_interconnect_0:mm_interconnect_0|stamp3_platform_designer_mm_interconnect_0_router:router"
The problematic lines of code in stamp3_platform_designer_mm_interconnect_0_router.sv are these:
always @* begin
src_data = sink_data;
src_channel = default_src_channel;
src_data[PKT_DEST_ID_H:PKT_DEST_ID_L] = default_destid;
// Address Decoder
// Sets the channel and destination ID based on the address
// ( 0x0 .. 0x400 )
if ( {address[RG:PAD0],{PAD0{1'b0}}} == 23'h0 ) begin <-- Line 195
src_channel = 4'b1000;
src_data[PKT_DEST_ID_H:PKT_DEST_ID_L] = 1;
end
// ( 0x400 .. 0x400400 )
// ( no optimization for non-address-span aligned address range )
if ( ( ( sink_data[PKT_ADDR_H:PKT_ADDR_L] >= 'h400) && (sink_data[PKT_ADDR_H:PKT_ADDR_L] < 'h400400) )
) begin
src_channel = 4'b0100;
src_data[PKT_DEST_ID_H:PKT_DEST_ID_L] = 3;
src_data[PKT_ADDR_H:PKT_ADDR_L] = sink_data[PKT_ADDR_H:PKT_ADDR_L] - 'h400;
end
// ( 0x440 .. 0x100440 )
if ( ( ( sink_data[PKT_ADDR_H:PKT_ADDR_L] >= 'h440) && (sink_data[PKT_ADDR_H:PKT_ADDR_L] < 'h100440) )
) begin
src_channel = 4'b0010;
src_data[PKT_DEST_ID_H:PKT_DEST_ID_L] = 0;
src_data[PKT_ADDR_H:PKT_ADDR_L] = sink_data[PKT_ADDR_H:PKT_ADDR_L] - 'h440;
end
// ( 0x480 .. 0x100480 )
if ( ( ( sink_data[PKT_ADDR_H:PKT_ADDR_L] >= 'h480) && (sink_data[PKT_ADDR_H:PKT_ADDR_L] < 'h100480) )
) begin
src_channel = 4'b0001;
src_data[PKT_DEST_ID_H:PKT_DEST_ID_L] = 2;
src_data[PKT_ADDR_H:PKT_ADDR_L] = sink_data[PKT_ADDR_H:PKT_ADDR_L] - 'h480;
end
My main problem is that my master has an address range of 22 bits. It is an external uC that I map as an avalon mm master using a bridge.
I now have 4 mm slaves with an address range from 0x0000 to 0x0047f (well within 22 bits) and I even use the System --> Assign Base Address option in order to fit better the address space.
However the compiler wants to map the addresses in more than 22 bits. Why does this happen and how can I avoid it?
