13 years ago
Error 10029: Constant Driver, Error 10028: Can't resolve multiple constant drivers
Hi, I am trying - processing/start/start analysis and elaboration - in Quartus 2 for the following VHDL code:
code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ber_count is
generic ( size : integer := 128);
port ( clk : in std_logic;
--clkp : in std_logic;
enc_valid : in std_logic;
dec_valid : in std_logic;
enc_data : in std_logic_vector ((size-1) downto 0);
dec_data : in std_logic_vector ((size-1) downto 0);
error_count : out std_logic_vector (7 downto 0)
end ber_count;
architecture behavioral of ber_count is
signal enc_buf, dec_buf : std_logic_vector ((size-1) downto 0);
signal ecount : integer := 0;
signal new_dec_data, new_enc_data : std_logic;
signal global_frame_count : integer := 0;
signal err : std_logic;
begin
load_encoded_data: process(enc_valid)
begin
if rising_edge(enc_valid) then
enc_buf <= enc_data;
new_enc_data <= '1';
global_frame_count <= global_frame_count + 1 ; -- if needed, we can use this value to calculate BER
end if;
end process;
load_decoded_data : process(dec_valid)
begin
if rising_edge(dec_valid) then
dec_buf <= dec_data;
new_dec_data <= '1';
end if;
end process;
count_errors: process (clk)
begin
if rising_edge(clk) then
if (new_enc_data = '1'and new_dec_data = '1') then
new_enc_data <= '0';
new_dec_data <= '0';
for i in 0 to (size-1) loop
err <= (enc_buf(i) xor dec_buf(i)) ;
--if(enc_buf(i) = dec_buf(i)) then
if (err = '1') then
ecount <= ecount + 1 ;
end if;
end loop;
end if;
end if;
end process;
error_count <= std_logic_vector(to_unsigned(ecount, error_count'length)); -- typecast integer into std_logic_vector
end behavioral;
code description: As you might have guessed this is code for an error counter module which buffers output frame from encoder and decoder, and compares
the two frames to find number of errors.
I am relatively new at VHDL, so the code might be a bit dirty (actually very dirty -_-).
errors: These are the errors I am getting : Error (10028): Can't resolve multiple constant drivers for net "new_dec_data" at ber_count.vhd(50)
Error (10029): Constant driver at ber_count.vhd(41)
Error (10028): Can't resolve multiple constant drivers for net "new_enc_data" at ber_count.vhd(50)
Error (10029): Constant driver at ber_count.vhd(31)
The indicated lines in the error message are denoted in Arial Black font in the code.
How do I resolve this problem ?
Leo
    In simple words, a signal can't be asigned a value more than once in concurrent code or in more than one process.
    In hardware terms, it's like two logic outputs driving one signal without a mux. You'll find more detailed information in your favourite VHDL text book.
    Thanks for your reply FvM.
    Mistake looks so obvious now. I will need to move the signal manipulation to single process.
    Will do that and post again if encountered a problem. Thanks again.
