10 years agoError (10028): Can't resolve multiple constant drivers for net <name> at <??>
All, Here is one of my Verilog trial-learning code: ============================================================== // Verilog learning example
module SRAM_Read_Write_Sync ( nrst, Writeclk, ...
10 years agoif you have a clock, the the only thing that should be in the sensitivity list (inside the brackets of the always) are the Readclk and nrst. You only care what happens on the clock edge, hence you dont want anything else. If you are trying to do logic with the clock, you are going to fail as this wont be possible in an FPGA. at the top level you should have:
always @(posedge Readclk or negedge nrst) begin
if(~nrst) begin
// asynchronous reset goes here
else begin
// this is for synchronous logic
end
// NOTHING ELSE HERE
end
