10 years agoError (10028): Can't resolve multiple constant drivers for net <name> at <??>
All, Here is one of my Verilog trial-learning code: ============================================================== // Verilog learning example
module SRAM_Read_Write_Sync ( nrst, Writeclk, ...
10 years agoOk, I see your point... and that would definitely come back and bite me sooner or later... but the following code gives me the same Error 10028, so how do I:
1) check for a negative edge on nrst to reset my counters 2) increment my 9-bit counters on their appropriate rising clock edges I've been trying to go through several tutorials and examples and I thought I understood some of it, but..... What/where can I find what is being meant by the "multiple constant drivers for ?????" As you can see I am very "green" to Verilog programming.. Hard for me to see the "hardware behavior picture" since I usually do schematic entry....// Verilog learning example
module SRAM_Read_Write_Sync_Verilog ( nrst, Writeclk, Readclk, EQ, write_addr, read_addr);
input nrst, Writeclk, Readclk;
output EQ;
output write_addr;
output read_addr;
// Declare the address counters as 9-bit counters
reg write_addr;
reg read_addr;
reg EQ;
// increment Write address or Read address or do a reset
always @ (negedge nrst)
begin
if (!nrst)
begin
write_addr <= 0; // non-blocking
read_addr <= 0; // non-blocking
end
end
always @ (posedge Writeclk)
begin
write_addr = write_addr + 1;
end
always @ (posedge Readclk)
begin
read_addr = read_addr + 1;
end
endmodule Thanks again, Keith
