10 years agoError (10028): Can't resolve multiple constant drivers for net <name> at <??>
All, Here is one of my Verilog trial-learning code: ============================================================== // Verilog learning example
module SRAM_Read_Write_Sync ( nrst, Writeclk, ...
10 years agoAll, I figured it out.
Following is code that seems to compile, don't know about the EQ yet, but I think I figured a way to reset my counters and increment my counters.// Verilog learning example
module SRAM_Read_Write_Sync ( nrst, Writeclk, Readclk, EQ, write_addr, read_addr);
input nrst, Writeclk, Readclk;
output EQ;
output write_addr;
output read_addr;
// Declare the address counters as 9-bit counters
reg write_addr;
reg read_addr;
reg EQ;
// increment Write address or Read address or do a reset
always @ (posedge Writeclk or posedge Readclk or negedge nrst)
begin
if (!nrst)
begin
write_addr = 0;
read_addr = 0;
end
else if (Writeclk)
write_addr = write_addr + 1;
else if (Readclk)
read_addr = read_addr + 1;
end
always @ (posedge Readclk)
begin
if (read_addr == write_addr)
EQ = 1'b1;
else
EQ = 1'b0;
end
endmodule So I needed to add all 3 checks in the first "ALWAYS" then check for active LO (!nrst) to reset the counters. Then complete the other edge clocks to increment the appropriate address_counter. Then start another "ALWAYS" and start expanding from here with more behavior!! Thanks all, Keith
