16 years agoI got similar results when I use the RTL level simulation (10% usage from simulation file, and rest on default of toggle rate of 12.5%).
I did use the tcl file from Altera to gather my vcd but its the same as doing the command vcd add -r /dut/* on modelsim. Thanks mehakchopra, I think what you suggest on functional setting will solve my issue of non-matching sim results. Good luck on your end. Thanks, -pete
