16 years agoI think if you use the vo file generated by Quartus for your simulation and not use the rtl (v/vhd) file and then generate the vcd file you might get the High confidence metric.
I have tried doing the same for smaller designs and it had worked for me. I am attaching the comparison between the two designs , one using the rtl simulation and one using the gate level simulation (vo file)
