14 years agoEPCS16 write one byte more than once
I'm trying to use the EPCS16 as storage memory for few bytes. The configuration is: Use Mega Function ALTASMI_PARALLEL without NIOS. I managed to read and write one byte the first time. When I try to rewrite in the same address the data keep the same. It is known any single byte write limitation? I'm using Quartus 11.0. Best Regards, Manpsilva
