13 years agoEPCS Flash Access on DE0 Nano (Qsys)
Hello, I'm having trouble accessing the EPCS Flash on a new DE0 Nano board. I've set up a Nios II system in Qsys and included the EPCS Serial Flash Controller. (Other system components include ...
13 years ago --- Quote Start --- Ah, my problem was in not properly connecting the EPSC data0 port to the appropriate pin. It did cause two compile time warnings. Too bad those got buried together with 20 other warnings. --- Quote End --- Does your DE0 nano have the EPCS64 Spansion chip? I still haven't found a solution, I've had to put the project on the backburner..
