Armen
5 years agoEncryption of Intel's FPGA IP
Having problem to encrypt FPGA's IP using Quartus version 19.1 on Cyclone 10GX: 10CX150YU484I6G part. need help as we shipping IP overseas.
I attached error message during Encryption procedure. See...
sstrell
5 years agoThe PFG is set to Cyclone 10 LP instead of GX. Is that the issue?
Armen
5 years agoThanks for the first reply, sstrell. I had no chance to choose GX part. Is it possible 10GX part is not supported at all?
Anybody who successfully encrypted POF for 10GX part?
Armen
- sstrell5 years ago
I don't know if you've read this guide, but this has info about encryption:
You can't encrypt and compress at the same time if that is applicable here.
- Armen5 years ago
Hi there , I know my problem. The issue was with the length of the key. There is no message telling that key is not 64 byte long. That's the reason, generate button was always greyed in Encryption dialog box.
Once, I got enough characters, Generate button activated and I was able to generate encrypted POF file
Amen
