Encryption for Cyclone 10CX150YU482I6G with Quartus 19.0
By not functioning at all, does it show any error message? If yes, can you provide us the error message and error code?
Have you also try to program this by using latest Quartus version? Quartus Pro 21.2?
Also, did you follow AN 556 on how to use design security features?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an556.pdf
Aiman
Hi Aiman,
I am following AN556 (Generating Single_device /ekp File and Encryption Configuration using Intel Quartus Prime Software) on page 14 . I go all the way to section 7 and can generate ekp file)
As for Section 10 I can not select Intel FPGA Ethernet Cable as my only choice is JTAG ( I have shared schematic already) and hence I can not produce jam,svf or ISC files.
However, if I generated encrypted pof files- I am able to program it using Active serial mode and as I mentioned before FPGA is not functional with that file. Keep in mind that I am able to get compressed or just regular pof file and successfully program and use FPGA
I am new to encryption, so if you can point out to my wrong steps.
So, I am stuck at section 10 Ethernet Cable to produce jam, svf files. Any solution to that? Can I bypass this and create encrypted file using JTAG or Active Serial approach.
Armen
