8 years agoEncoder for dsd audio stream in SDIF-3 format, VHDL - help a newbie
Hello folks, I'm a newbie in VHDL programming. I'm trying to achieve SDIF-3 encoding from a dsd datastream coming off from an A-D conversion chip. The dsd stream from the chip features two...
8 years agoI am afraid that you will have to step up to MAX-10 to get DDR IO.
I checked the MAX-V data-sheet/handbook and couldn't find a reference to DDR IO operation. I you want to use MAX-V (or MAX-II) you better use a clock with twice the bit-rate, which should pose no issue for SDIF-3 speeds
