EMIF Questa Simulation very slow
Dear Intel Support/FPGA Expert,
I instantiate an Arria 10 GX Develop board DDR4 72bit EMIF in an ultrasound system. the EMIF itself will reduce the whole system simulation speed for almost 10 times. with this module enabled, the simulation runs about 13ns for every second. if I disable this module, the simulation can run 130ns per second.
Is there any way to accelerate the simulation speed with this EMIF module?
here is another question, I have posted on the forum before.
while running the simulation with emif enabled, it will show this kind information, is there a parameter that I can turn it off.
[2238863560] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: Initiating Read operation from [0x9aab]
# [2238863560] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: READ Warning: IOAux detected dirty input data.
# It is possible that your read operation may contain invalid data.
# [2239014600] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: READ: [0x9aab] => 0x0000000a ( 31 cycles)
# [2241129160] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc420] <= 0x00000000
# [2241280200] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc421] <= 0x00001f00
# [2241431240] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc4a0] <= 0x00000000
# [2241582280] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc4a1] <= 0x00001f00
# [2241733320] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc380] <= 0x00000000
# [2242035400] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x6080] <= 0x00000008
Thank you,
David
Hi David,
I hope you're doing well.
Do you have any further question or feedback regarding this topic?
Adzim
- AdzimZM_Altera
Hi David,
There is one way to make the simulation running faster.
You can enable the Abstract-PHY mode together with the Skip Calibration mode in the EMIF IP.
When you make a change in the EMIF IP, you have to regenerate the IP.
Adzim
- AdzimZM_Altera
Hi David,
Adzim
- dsun01
Contributor
Hi Adzim
I haven't try it yet. I accept as a solution, if I have any further question I will open a new topic. thank you very much.
David
