8 years agoEmbedded JAM byte-code player failure with Quartus 17
Hi all I implemented the Jam STAPL ByteCode Player (revision 2.2) on an embedded platform in order to program/configure a MAX10 FPGA via JTAG directly from an embedded processor. This was ...
8 years agoHi
No I was not able to achieve success with the tools as is... What I currently do is to compile my FPGA image in Quartus 17 and then I use the "quartus_cpf.exe" utility from the Quartus 16 install directory to generate the JBC format. (Instead of generating the .jbc from within Quartus 17) "Unrecognized device" does sound like it might be a different issue though, can you confirm that the device ID is being read correctly?
