8 years agoEmbedded JAM byte-code player failure with Quartus 17
Hi all I implemented the Jam STAPL ByteCode Player (revision 2.2) on an embedded platform in order to program/configure a MAX10 FPGA via JTAG directly from an embedded processor. This was ...
8 years agoDid you ever figure this out?
I'm having a very similar problem, but the STAPL files built with Quartus 18. Works fine when created with Quartus 16, using the non-bytecode player 2.5. I also see the new "configuring SRAM" step. However, mine fails on "Exit code = 6... Unrecognized device", so the failure may be slightly different.
