11 years agoThe problems you are having sound like what Tricky said in the first response, where Quartus isn't mapping your HDL code to M4K elements, it's mapping it to LE's. Did you write the code yourself, or did you use one of the templates or the recommended coding guidelines?
If you use MegaWizard to create a 256-bit ROM and just connect the 237-bits you care aobut, you'll get zero LE used.
