11 years ago --- Quote Start --- what if you try a small rom and instantiate it as many as you like then connect the 273 bits manually, all with same address. I don't see if it will need any extra logic --- Quote End --- I guess my only problem with this is it will make creating the instantiation files kind of a pain, since I have to split up data that is logically contiguous into 15 or 20 files to get the width down to 16 bits.
