Edit IP Catalog IP and saving to different name
I try install Quartus lite to my windows 10 machine. I don't see this problem.
can you try the below:
1) Can you try on different project to see if is project specific issue?
2) install currprocess https://www.nirsoft.net/utils/cprocess.html and disable all the software running behind there
3) disable the anti virus
4) close all the Quartus software
go to c:/user/<username>/ rename the quartus2.ini and quartus2.req for windows
cd to home/<user>/.altera.quartus rename the quartus2.ini and quartus2.req for linux
and reopen the quartus. this will reset the initial setting of the quartus prime.
5) did you install all the devices?
6) check if you have spaces in your directory names? If you had, try to replace the spaces with underscores.
7) delete .altera.quartus
