14 years agoYou could just install Quartus II full-edition. That'll get you the libraries. It doesn't matter than you cannot run the software. In fact, I think you can run the software, but only for 30 days.
Modelsim-ASE can be used in single-language mode. You could install it too, just as a test to see what libraries are needed to get things working. Unfortunately, the Modelsim compiled libraries are not compatible, so you can't just vmap the Modelsim-SE libraries to point to the Modelsim-ASE libraries. I have Modelsim-SE and ASE installed. Cheers, Dave
