Patriet
5 years agoeda sim_lib vlog compile error...missing tennm_atoms_ncrypt.sv
Trying to conpile eda sim_libs for Mentor and getting an error about missing .sv file. Error is below. Error: # ** Error: (vlog-7) Failed to open design unit file "/apps/quartus_prime/19.2.0/insta...
- 5 years ago
Yes, once you installed the Agilex device, the .sv file will be shown.
RichardT_altera
5 years agoI believe the files is used for Agilex devices. I checked, starting from Quartus Pro version 19.1 and onwards you should be able to see the tennm_atoms_ncrypt.sv files located in the <installation directory>/quartus/eda/sim_lib/mentor/
Patriet
5 years agoThanks for the reply. Does that mean those .sv files will not show up unless I install the agilex device family maybe??
- RichardT_altera5 years ago
- Patriet5 years ago
Thank you, that worked. I installed the Agilex device family and the missing files appeared. Please note that Agilex devices are not supported until 19.3.
