8 years agoEasiest Testbench for my VHDL code (multiplication)
Hello there. Is there somebody who can make testbench from my vhdl code? It is multiplication of 2 integers, which are n-1 downto 0.. n=16. Thanks a lot.. library IEEE;use IEEE.STD_LOGIC_1164.A...
8 years ago --- Quote Start --- Hi Have you tried option 1?? Learn to write test-bench google it. http://eng.umb.edu/~cuckov/classes/engin341/lectures/l02%20-%20vhdl%20-%20dataflow%20and%20structural%20modeling%20and%20testbenches.pdf
--ONE OF THE WAY OF WRITING TB IS SHOWN YOU CAN USE LOOPS TO TEST ALL THE CASE
stimulus: process
begin
a<="0101";
b<="0101";
wait for 20ns;
a<="1111";
b<="1111";
wait;
end process;
Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Hello, i have tried with Q too or i dont need to? I got errors: # ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(96): near "'": syntax error# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(97): near "'": syntax error# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(98): near "'": syntax error# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(100): near "'": syntax error# ** Error: D:/altera/13.0sp1/nasobenie/nasobenie_tb.vhd(104): VHDL Compiler exiting# ** Error: D:/altera/13.0sp1/modelsim_ase/win32aloem/vcom failed. This is my code for test bench:
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_Std.all;
entity nasobenie_tb is
generic
DATA_WIDTH : natural := 4
end;
architecture bench of nasobenie_tb is
component nasobenie
generic
port
a : in signed ((DATA_WIDTH-1) downto 0);
b : in signed ((DATA_WIDTH-1) downto 0);
q : out signed ((2*DATA_WIDTH-1) downto 0)
end component;
signal a: signed ((DATA_WIDTH-1) downto 0);
signal b: signed ((DATA_WIDTH-1) downto 0);
signal q: signed ((2*DATA_WIDTH-1) downto 0) ;
begin
-- Vlozenie hodnot pre parameter generic !!
uut: nasobenie generic map ( DATA_WIDTH => DATA_WIDTH )
port map ( a => a,
b => b,
q => q );
stimulus: process
begin
a <= '0000';
b <= '0000';
wait for 10 ns;
assert(q = '00000000');
a <= '0001';
b <= '0000';
wait for 10 ns;
a <= '0010';
b <= '0000';
wait for 10 ns;
a <= '0011';
b <= '0000';
wait for 10 ns;
a <= '0100';
b <= '0000';
wait for 10 ns;
a <= '0101';
b <= '0000';
wait for 10 ns;
a <= '0110';
b <= '0000';
wait for 10 ns;
a <= '0111';
b <= '0000';
wait for 10 ns;
a <= '1000';
b <= '0000';
wait for 10 ns;
a <= '1001';
b <= '0000';
wait for 10 ns;
a <= '1010';
b <= '0000';
wait for 10 ns;
a <= '1011';
b <= '0000';
wait for 10 ns;
a <= '1100';
b <= '0000';
wait for 10 ns;
a <= '1101';
b <= '0000';
wait for 10 ns;
a <= '1111';
b <= '0000';
wait for 10 ns;
end process; --koniec opisu procesov
end bench; --koniec opisu architektury tb
configuration cfg_bench of nasobenie_tb is --konfiguracia test bench entity
for bench --cyklus je prazdny, nema ziadnu specificku funkciu v nasom pripade
end for; --koniec cyklu
end cfg_bench; --koniec opisu konfiguracie
