i have similiar problems with the ASDO and the nCSO Pin which is shown in the following picture (view the link)
ht tp://
img63.imageshack.us/img63/7448/errormessagee.png So there is no possibility to use this "pins as regular IOs"
(Assignments->Device->Deivce and Pin Options -> Dual-Purpose-Pins)
The pins can only used "as input tri-stated"
BUT: in another projekt i build, there isn't the problem with the both pins.
Has anabody an idea, which assumedly simple configuration point i have to chance?
Thank you
Dev.-Enviroment
FPGA: Cyclone2 - EP2C35F672C8
Quartus 9.1
