Dual port RAM Cyclone 5
In the Quartus text editor true dual port RAM (dual clock) template (Text Editor Edit menu -> Insert Template), it's a bit different from what you have. New data would imply that on write, you should have, along with writing to the RAM:
p1_dout <= p1_din; //similar for p2
You're also missing in your if statements an else check for if p1_we (or p2_we) are low:
p1_dout <= mem[p1_addr]; //again similar for p2
I'm also not sure if there are separate RAM enable signals like what you have (p1_ena and p2_ena). They are not in the template.
Any of these could affect how the RAM gets inferred and whether extra external logic gets added to match your behavioral description.
- AEsqu4 years ago
Contributor
Thank you,
I couldn't reach the edit/insert template as it only popups when a file is open with the Quartus editor.
I think the template generator should always be available.
I will create one from it and try, thanks again sstrell.
