RRomano001
Contributor
7 years agoDual Compressed Image not showing on configuration mode drop down list for MAX10
Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition Another user reported this same issue, thread is locked:
- 7 years agoHi, You are selecting the compact variant device which does not support dual compress image. Please change the device by following the device guideline in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_overview.pdf Figure 1.
JohnT_Altera
7 years agoHi,
- RRomano0017 years ago
Contributor
Hi JohnT, I grasped now what is SC , I read thoroughly again document you pointed me to.
Page 6 report difference from compact flash, analog and yes SC just from that are single image.
from table on same page, only 02 seems single image, all other in row are 2 image.
After thinking about page 5 figure 1 part numbering and table 3 I realized table 4 refer to maximum size 0x dependent.
SC if I understood are all single image regardless of LE size.
Thank for clarify this, SA are too much expensive, I try check pinout to see if there where interchangeable in case I need dual image.
Thank you
