10 years agoDSP usage issue with arria10
The following circuit is designed to fit in 2 DSPs on StratixV FPGA: http://www.alteraforum.com/forum/attachment.php?attachmentid=11892&stc=1 -> a,c,e and g are input ports (signed) -> ...
10 years ago --- Quote Start --- At first glance, I cant really understand why. It could just be a compiler bug with inference ie. you're not quite using the template expected. have you tried using separate intermediate signal outside of the clock process for the multiplication and addition, with only the final register in the process? Have you tried using intermediate variables instead? --- Quote End --- I did. Same behavior with this piece of code:
abcd <= (a * b) + (c * d);
efgh <= (e * f) + (g * h);
abcdefgh <= abcd + efgh;
dataout <= abcdefgh_reg;
p_register : process(clk)
begin
if rising_edge(clk) then
abcdefgh_reg <= abcdefgh;
end if;
end process p_register;
