ThangND
5 years agoDSP Builder MegaCore Import Error
I'm creating a block in DSP Builder using the MegaCore Import in the library. After instantiating the block with all the necessary parameters in Qsys, I've generated HDL file and then return to DSP B...
CheepinC_altera
5 years agoHi,
Sorry for the delay. As I look into the latest DSP Builder Advanced handbook, it seems like I am unable to locate the alt_dspbuilder_setup_megacore. From the latest handbook, the HDL import is using HDL Import Configuration and HDL Import blocks. Can you install the latest DSP Builder version and check out the "DSP Builder HDL Import Design Example" in the handbook. When you open up the hdl_import_duc.mdl, you will see detailed step by step guiding how to import HDL into the example design.
