ThangND
5 years agoDSP Builder MegaCore Import Error
I'm creating a block in DSP Builder using the MegaCore Import in the library. After instantiating the block with all the necessary parameters in Qsys, I've generated HDL file and then return to DSP B...
ThangND
5 years agoHi,
I'm using Quartus version 16.1 and Matlab R2018a. As you can see, I'm having trouble with the megacore functions in DSP Builder. For example, I'm using the FFT Megacore Functions to generate the IP, but there are still the errors:
I've already run the command "alt_dspbuilder_setup_megacore" as suggested in the DSP Builder Handbook for installing the megacore functions. Did you have any problems with using the megacore functions like that ever before ? Let me know if you have any ideas to fix this error. Thank you.
