ThangND
5 years agoDSP Builder MegaCore Import Error
I'm creating a block in DSP Builder using the MegaCore Import in the library. After instantiating the block with all the necessary parameters in Qsys, I've generated HDL file and then return to DSP B...
CheepinC_altera
5 years agoHi,
As I understand it, you encounter some problem with the megacore import. By merely looking at the error message, it seems to say that the target directory that you are importing is no accessible. One of the possibility is due to the write permission to that directory. Would you mind to share with me you files, detailed steps to import and DSP builder version that you are using? I would like to try performing problem replication on my side if I have the right DSP Builder version. Thank you.
